The PSP 3000 was released in the U.S. on the 15th of October 2008.
92 Questions View all
Accidently plugged laptop charger into PSP...
So as I said, wasn't paying attention and accidently plugged the laptop charger into it while it was on. And naturally it instantly turned off, now it won't turn on, and won't charge the battery won't turn on with only the "actual" charger plugged into it.
I've read around about a fuse on the motherboard, but I've taken this thing apart and apparently no one has ever had to fix this TA-095 motherboard because it doesn't have the same set-up as any of the ones I've seen so I don't even know what to try and bridge together. So was looking for some pointers, or if someone knows what exactly the issue might be. Thanks!
Edit: I just grabbed a front/back picture off google of the motherboard since I've already reassembled it for now. Hope thats okay!
1 Comment
@zantetsuken for now do not apply a jumper to anything. You do wnat to go ahed and post some good pictures of both sides of the motherboard as well as the power board of your PSP3000 with your question. Use this guide Adding images to an existing question for that. It will allow us to see what you see.
by
Add a comment
1 Answer
Chosen Solution
@zantetsuken the very first thing you want to do is check the power board for any sign of damaged components. After that get your multimeter and check the power fuse for continuity. If it does not have continuity it will need to be replaced.
Score 1
1 Comment:
Where would one find a replacement fuse? I am assuming the power fuse and charging fuse are seperate?
by
Add a comment
Add your answer
Chris will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 20
All Time: 2,720
