Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
544 Questions View all
How to fix a broken battery connector pin?
I have a MacBook Pro 17” (mid-2009, Model A1297). I have successfully replaced the battery three times in the past.
Today, as I attempted to plug in a new battery, two of the thirteen pins in the battery connector on the main logic board got bent. Though I was extremely cautious and careful in trying to bend them back straight using tiny tweezers, they both broke off.
My options don’t appear good. As I see it, I could buy a new logic board (which appear to be about $430+ on Amazon); or I could go to someplace like MicroCenter and let them fix it for a $ amount I can only imagine.
Are there any other viable options? For example, is it possible to de-solder the old battery connector off the logic board and solder on a new one (assuming one could find a replacement connector)?
Please help with any ideas.
Thanks
Add a comment
Most Helpful Answer
Yes it's possible to solder a new one; you will most likely need to desolder one from a donor/dead board and move it across to yours. You can heat the opposite side of the logic board to remove this without melting the plastic connector. Not aware of a source for new ones, I just remove from donors if I ever need connectors like this
Score 6
4 Comments:
Your answer is most welcome, and gives me a bit of hope. You made my day — thanks.
Ted
by
I'm in the same boat, and struggling to find a new socket, so now looking for a donor logic board to salvage the port from.
by
Does anyone know what the part number for this component is as I have the same problem ?
by
@stuart1 the connector is listed as a GS731301047E7H but it might be easier to buy an old/broken board and use that to harvest the connector from.
by
Add a comment
That's wonderful, many thanks. They certainly seem hard to come by !
Add a comment
Add your answer
Ted will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 8
All Time: 1,474
