Why is my new Hard Drive not seen by Disk Utility?
I wish to replace the fully working 120GB HD with the upgrade 320GB WD3200BEVE drive to gain capacity.
When I fit the new blank HD, fresh from WD, and boot from a system DVD, the HD is not seen by System Profiler or Disk Utility.
I have used the same HD cable and this is the second drive with the same problem. If I refit the 120GB HD the machine works as normal.
I have checked for Firmware updates, there don't seem to be any for this machine.
Any advice please?
Score -1
Add a comment
1 Answer
Chosen Solution
Well I fixed my own problem.
The previous owner was a tinkerer like us, and had fitted an HD ribbon cable which worked with a 120GB HD, but not with a larger drive. It may be faulty, or from another model. When I fitted a different cable 'borrowed' from another PB the new 320GB drive was seen as expected.
Score 2
Add a comment
Add your answer
Cameron will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 902
