Sonos Play:1 was released on October 2013. It is a wireless speaker system that features a 3.5 inch mid-woofer and tweeter. Repair of this device requires screwdrivers, tweezers, and prying tools. Model number: PLAY1US1BLK
14 Questions View all
My unit is not powerin on after a voltage spike
i had a voltage spike in my house and the live was going down the neutral leg , now my sonos play 1 does not work , is there a fuse in the circuit or will it be just the power transformer i need to change
Score 2
Add a comment
1 Answer
Chosen Solution
Hi @dragonsden ,
It may not be as simple as a fuse (if there is one) or the transformer. It may be something else such as a burnt out capacitor or diode etc.
Here is a link to the ifixit guide on how to remove the motherboard of the speaker.
Once you have accessed the motherboard you may be able to ascertain the extent of the problem. Hopefully it will be something that is obvious, such as a burnt out component. Again it is hoped that the information printed on the faulty component will be legible enough for you to be able to obtain the correct value replacement part.
If you have difficulty identifying an obviously faulty component, post some pictures and perhaps someone here will be able to help. Here's how Adding images to an existing question.
If there is nothing obvious to be seen you'll need to get technical and start doing some point to point testing of the circuit with the power disconnected, using an Ohmmeter, to narrow down where the fault lies.
Hopefully this is of some help
iFixit Image
Guide
Difficulty:
Very easy
2 - 5 minutes
Sonos Play 1 Motherboard Image
Guide
Sonos Play 1 Motherboard Replacement
Difficulty:
Moderate
30 - 35 minutes
Score 2
Add a comment
Add your answer
kevin Owen will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 18
All Time: 853
