"Unable to join WiFi network" How can I fix this?
So, my iPod Touch 1G just arrived today and for some reason, the WiFi has a weak signal and it says "Unable to connect to the network". Does anyone know how to fix this?
Unplug and plug in router. Move close to the router (try this step first). Restart iPod. If all else fail try full erase.
Is the iPod used? Or new? A used iPod might need the Wifi antenna replaced or it could’ve come disconnected. Most of those are little (coax) cables but they look different in a phone or ipod/iPad. I wouldn’t suggest doing this yourself because iPods are the hardest Apple device to get into unless you like soldering. Sorry for the late reply. I hole this helps if you’re still having the problem
Everything i tried failed, even the reset. What do I need to fix?
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 16
All Time: 472
