A television game console produced by Sony Computer Entertainment; the PlayStation 4 Slim (CUH-2000 Series) is a thinner replacement model for the original PS4. Announced September 7, 2016.
572 Questions View all
PS4 Slim takes multiple attempts to turn on
Hey
I have a PlayStation 4 Slim 500gb(CUH-2016a) and has bit of a problem.
When I turn it on, 8/10 times it beeps, gives blue light and turns off. I have to switch off the outlet, wait and then turn the outlet on then attempt to turn on the PS4. If I don't turn off the outlet and press the power button there's no response, no blink or beep, completely cold. Sometimes it turns on in 1 attempt or sometimes even directly, sometimes you have to repeat the process 5-6 times. (Doesn't matter if you turn on from power button or controller)
When it turns on it works perfectly fine. Does not power off or anything. I have re-initialized it but problem persists. Also changed the power cord but to no use. I suspect a power supply issue. Any ways to resolve it?
Score 1
Add a comment
Sounds like the power brick is faulty, unfortunately there is no guide on how to replace this on fixit but you could follow the teardown video for a rough guide on how to replace this.
1 Comment:
When you say power brick, does that mean the whole power supply or one specific component within that?
by
Add a comment
Need help
Add a comment
Have you solved this exact issue? I had to replace my old PSU because of this back in 2017 and now here I faced the same issue on the second PSU and don't know what to do with it other than replacing…
Add a comment
Add your answer
Saad will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 29
All Time: 1,779
