Repair guides and support for the first generation Nissan Murano, from the 2003 model year to 2007.
19 Questions View all
My 2005 Nissan Murano is not accelerating over 60mph on the highway?
Hello there, so I had an issue initially with my throttle body, got it replaced. After replacing it, I keep getting a code about idle re-learn. I did the procedure correctly to set off the engine code. Now my 2005 Nissan Murano is not allowing me to go past 60mph when I get on the highway. After replacing the throttle body and re-learning the idle, my cars acceleration isn't up to par and I can't figure out what it is that's preventing me from getting this fixed. Appreciate everyone that reads this, any feedback would be helpful. Thank you
Add a comment
1 Answer
Had similar problem, had rpm but not much speed. Would take longer time to get up to speed( 60 mph). Found that the cvt ( tranny) was bad, new tranny problem fixed. Also check voltage, bad alternator , low voltage, than you get no rpm when stepping on peddle, also could be battery with low voltage( bad or shorted cell) The cvt is excellerate by wire( voltage), no or low voltage , no speed. Hope this helps
Add a comment
Add your answer
David Mendoza will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 11
Past 30 Days: 41
All Time: 4,157
