Audi Q7 turned off and wont crank
Hello short story i was driving normaly took a turn and then steering wheel got heavy the car turned off, messages appear in the screen saying alternator not charging the batterie, eps malfuntion, gearbox limited , and the car wont even crank all accesorys worked but they where dimming so i replace the battery but nothing any tips?
Score 1
Add a comment
Chosen Solution
it was the ecu got water damage dont know how but it did
3 Comments:
How did u find out it was your ecu?
by
ecu is on the passanger side open the hood and under the wiper blade there is a black cover
by
Life saver!!!!!!!
by
Add a comment
Following are the common solutions to kickstart your Audi Q7 once again:
- Battery Replacement
- Fuel Pump Replacement
- Ignition Switch Replacement (Electrical)
- Ignition Lock Cylinder Replacement
- Starter Replacement
- Camshaft Position Sensor Replacement
- Crankshaft Position Sensor Replacement
- No Start Diagnosis
Add a comment
Add your answer
carlos will be eternally grateful.
Past 24 Hours: 6
Past 7 Days: 23
Past 30 Days: 73
All Time: 2,312
