The Chevrolet Cavalier is a compact automobile produced from 1982 to 2005 by General Motors.
139 Questions View all
Why can't I shift 2003 Cav manual transmission into any gear?
2003 Cavalier with manual transmission lost ability to shift while shifting from 1st to 2nd. The shifter feels loose now and I am unable to shift into any gear. I am able to move the shifter into the correct positions, but feels loose- like something (shifter linkage?) has become disconnected or broken, and does not move manual transmission into any gear at all. What do you think? Where can I find a free diagram to isolate suspected components?
2 Comments
I am currently having this exact problem. The link to the solution is broken. Any info would be greatly appreciated
by
Have the same issue but linkage works fine can't go into gear with or without clutch meaning free play like linkage is broke but on the trans where the linkage is hook to moves freely thanks for any advice
by
Add a comment
Chosen Solution
Sounds like you've dropped the pivot bolt. Here's how to fix it: http://www.dmctalk.com/showthread.php?t=...
Score 2
1 Comment:
The link will not load
by
Add a comment
Hi @sarahphill66113
Here's the parts diagram for a 2003 Chev Cavalier manual transmission shift control that may help
Score 1
Add a comment
Add your answer
Diver Down will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 14
All Time: 4,511
