Amp turns on no power
I have fender sidekick reverb 30 turns on no sound tried to look it up everyone is 25 or 35 model reads sidekick30 reverb serial sk3 2250 I can't get any information on this at all please help
@edwardo01 let us know what you have checked so far. Make sure that all your inputs are okay. right now it sounds like you are having issues with the actual amp section. From a schematics perspective there is not much difference between the Reverb 35 and Reverb 30
Apparently there were problems with the 1/4 inch jacks in these amps. apparently the speaker output is routed through those. So if it failed, you will have a broken circuit to the speaker. Post plenty of pictures what your amp looks like on the inside. Use this guide Adding images to an existing question for that. It will allow us to see what you see.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 15
All Time: 798
