Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Questions View all
Question Closed
Changed a broken screen and touch area doesnt work proper
I changed my broken glass on my Iphone 3GS all turned out to work good. But i descouver that the touch screen messed up. For an example i go in keyboard mode and try to write and when i press J i got a G and so on. It seems that the screen sence my finger wrong. Everything i press on makes something else activated at the left of the fingers point position. If i want to open a sertan app i have to press the app at the right side to get it activated. So what can i do...?
Add a comment
Most Helpful Answer
You have got the wrong screen a 3G will not work properly in a 3GS check your model number on the back of the Iphone
Score 3
Add a comment
A 3g screen will not plug into a 3gs mother board and visa versa. The connections are different, 3gs screen connections has two rows of prons/teeth with a black space between, 3g has 3 rows of prons/teeth and no space. Most likely the connections popped loose when lowering the screen back down to the phone, double check that the connections are flat and secure. Sometimes you'll get defective screens, make sure you buy original oem pieces and not generic "clones" although they work fine. Two types of clones are called High copy A and High copy AA. Single A is best "clone" quality. AA is good too, but not so much. Original "Just like the one you bought from store" pieces would be adveritised. Sellers say their parts are oem but are most times clones. Make sure the connections are on and you talk to sellers before purchasing.
Score 1
1 Comment:
+ Just like anything else, you get what you pay for and sometimes your get poked in the eye ;-)
by
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 2,081
