Repair guides and support for motherboards and CPUs.
166 Questions View all
Asrock P67 pro3 has a broken component
Hi Folks,
My friend has came across with his broken PC where I've found a burned out component on the Motherboard Asrock P67 pro3 , but wasn't able to read a top layer with model on it. Can someone give an advice which micro-component should I get for a replacement? Thank you :)
Add a comment
1 Answer
Chosen Solution
Hi Tarlan Isaev,
If your computer is running slower than usual, randomly freezes or restarts, or refuses to boot, see the Motherboard Has a Faulty Capacitor problem page for capacitor troubleshooting help.
are you referring to this? based on the circuit F5, it is a fuse
normally fuse blow can be due to surge or faulty ICs / transistor that draws alot of power and yea....
else the arrow you pointed could be a smd capacitor,
you need to get schematics to know the actual value of the components.
Score 2
2 Comments:
Hi Augustine,
Thank you for getting back :)
I'll have a look to the schematic of it, hopefully it's not so hard to find out :)
by
Hi Augustine,
Eventually I ordered a wrong fuse. So I decided to solder a tiny wire between two pins and finaly the motherboared has became alive :)
Again thank you very much :)
by
Add a comment
Add your answer
Tarlan Isaev will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 502
