The Pontiac Grand Am is a mid-size size (and later compact) car produced by Pontiac. The 1999-2005 generation is the final generation of the Pontiac Grand Am.
150 Questions View all
Why is my 2001 pontiac grand am gt still over heating?
I have replaced my resivor cap, water pump, thermostat, and bled it added new 50/50 had it flushed and cleaned twice and my car is still overheating not long after it warms up. It makes a bubbling sound and runs hot and the temp rises . I was told from a friend that is a mechanic it sounds to him like the intake gasket needs replaced. I am lost when it comes to cars. Any help please ?
Add a comment
This sounds like head gaskets to me. I was an ASE Master Certified tech with L1 and X1 certifications until I chose to pursue electronics repair due to back problems. These GM engines are well known for the intake gaskets leaking both internally and externally but weren't normally the cause of overheating unless the coolant level was low due to loss/leaking. Your description of "bubbling" further supports the head gasket theory since the head gasket (when failing) will allow combustion gasses from the cylinder into the cooling system. These gasses create pockets throughout your cooling system, causing poor coolant circulation, and sometimes a vaporlock that prevents any circulation at all, all of which will result in overheating situations. Sometimes you can see these bubbles when the engine is run with the radiator/or reservoir cap off ( EXCERSISE CAUTION WHEN WORKING ON A HOT ENGINE!!). A local shop should be able to verify the head gasket failure with a test. If they are found to be faulty, the repair would also entail replacement of the intake gaskets, so that issue shouldn't plague you in the future. Good luck, hope this helps.
Add a comment
I have a 2002 grand am and i got new water pump and thermoatate put in and after driving for 15 mins it is still over heating please
1 Comment:
Did you ever get it fixed
by
Add a comment
Add your answer
casey dixon will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 17
All Time: 1,599
