Support for gas-powered and electric golf carts, sometimes referred to as golf cars or club cars after the Club Car Golf Cart brand.
495 Questions View all
Will not run solenoid clicks
I have a 48 volt 2002 club cart the solenoid clicks but the cart doesn't move. When I check the solenoid it has 51 volts on the side coming from the battery. When I turn the key on the other side has 51 volts also. When the peddle is pushed it clicks but doesn't move. Is the solenoid bad? I have replaced the switch on the peddle.
Score 1
Add a comment
Most Helpful Answer
@felixday your voltage sounds fine. Since you already replaced the switch next would be the solenoid.
Score 1
Add a comment
Did the new solenoid solve the issue?
Add a comment
Add your answer
Felix Day will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 21
All Time: 5,119
