Fourth generation of iPad, released November 2, 2012, available in 16, 32, or 64 GB models. Model Number A1458
218 Questions View all
How to charge battery without logic board
HI
I have faulty Logic board ,most likely charging circuit on iPad 4
Is there a way to charge battery without using logic board so called " jump start" , as i am almost sure charging circuit is not function and battery not being charge , can i just use usb charger ,old usb cable ,strip down wires and connect red and ground directly to battery ?
Also
Should ipad works without battery connected to logic board? just lighting cable connected directly to logic board viaDock Connector Charging Port Flex Cable and usb to mac computer, should itunes detect it this way or needs battery ?many thanks
Score 1
1 Comment
Did you fix it? I have the same problem
by
Add a comment
1 Answer
Chosen Solution
Unfortunately the iPad can not be switched on and boot successfully with no battery connected and charging cable plugged in.
To boot up the iPad you either need a working battery connected to the logic board or soldered wire to the battery connector hooked up to a DC bench adjustable power supply.
Battery can be charged by using some special adapter to connect to DC bench power supply or by just soldering wires to it and connecting it to the power supply, provided you charge at around 2A max and with a voltage of at least 3.7(min)-4.2V(max).
Score 4
3 Comments:
Great, thanks for helpful tip.really appreciated
So how about if i use iPad charger and lightining cable with exposed wires. Connecting red and ground ( cable end) to small battery board + and - . Would that works.thanks again
by
If this is being charged over USB to wall charger this won't be a good idea as it will pump 5v into the battery which will damage it. 4.2v is the maximum specified voltage for the battery.
by
Ok got it
Thanks
by
Add a comment
Add your answer
Krzysztof Szarkowski will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 16
All Time: 1,887
