0
Score
Avatar
aksolanki
11
Asked
Intermittent audio in one channel?
History
Hello, does anyone know what the cause of the intermittent audio from the headphone jack is?
The fix is pretty straight forward, but I was wondering if anyone knew the cause of this problem? I have seen a few iPods with this fault. If I fix mine will the fault come back over time?
Edited by
aksolanki, did you get it fixed?
oldturkey03,
Post Answer
Score
Avatar
oldturkey03
59.5k
Answered
Accepted Answer
PermalinkHistory
aksolanki, when you say the fix is "pretty straight forward" does that mean you already fixed it or know what is broken that needs to be fixed? I am confused by that. The main audio issues besides the head phone jack of course Installing iPod 5th Generation (Video) Headphone Jack & Hold Switch available at iPod Video 60/80 GB Headphone Jack & Hold Switch is a loose IC on the logic board. You will probably know that you can fault find this by squeezing your ipod on the right bottom beside the click wheel if that resolves your audio issues, your IC is loose. Your fault can always come back if the repair is not done properly. Good Luck
Edited by
Product Image
Includes headphone jack & hold switch — 35 available at 29.95 each.
Hi oldturkey03, Thanks for your input. I didn't know there was an issue of a loose IC with some 5th Gen iPods, which is why I posted the question. The headphone/hold switch replacement seemed pretty easy to me, but I do have experience opening tech and fixing it. I have an iPod 5th Gen with a faulty headphone jack which I recently purchased from eBay, for the sole purpose of upgrading the HD to 240Gb, and by passing the internal Op amps and going straight from the Wolfson DAC to the line out on the dock connector. So I'm hoping that whatever the cause for the intermittent audio from the headphone jack won't affect me because I will be using line out to a portable amp. Many thanks, Anil.
aksolanki,
Hi Anil here is a good forum I came across a couple of years ago and it does explain a lot more about this issue. http://forums.macnn.com/103/ipod-iphone-... Check on a posting by warnergt it is kind of crude but it does seem to work.
oldturkey03,
0
Score
Avatar
aksolanki
11
Answered
PermalinkHistory
Many many thanks oldturkey03,
You have been very helpful, I'm grateful.Many thanks Anil.
You are very welcome. Thank you for accepting my answer and good luck to you.
oldturkey03,
Add Your Answer
