2
Score
Antiker
25
Asked
unknown "Screw" from my iPhone 4
Hello,
I want to change my iPhone from black in white. Now i have a "screw". I do not know from where this is.
Here are two pictures. Where i have to install this thing? Sorry for my English.
Edited by: oldturkey03, rj713, and machead3 ( ) , rab777hp ( )
4
Score
rab777hp
13.6k
Answered
Accepted Answer
What you need is iFixit's iPhone 4 liberation kit to remove the pentalobe screws from the bottom and to install phillips screws you can remove with any old screwdriver.
2
Score
doug2k
25
Answered
Hey Doug here....That is a nut that goes in between the motherboard and the back of the screen. Its a little hard to explain but there is a cover plate that takes 5 screws next to the camera and covers the connectors...it goes under the lowest screw....under it and the screw goes right thru it.... hope this helps
2
Score
Mike D
19
Answered
doug 2k is correct.. i just installed a color lcd assembly swap and that same lil bugger came off my logic board. the location of this piece is hard to explain but doug did a pretty good job.. look on the logic board, to the right of the rear camera connection, there is a little metal piece of the EMI cover that looks like a Y but rounded, that little piece that fell off went under there..
i'm not exactly sure if the piece is mandatory but my phone is functioning without it..
if you look at step 13 here, (Installing iPhone 4 Logic Board) your "screw" insert would belong beneath where the yellow circle is..
i dunno how one would repair this part... mayyybe using some krazy glue gel (?) ---> which i wouldnt recommend because that would be apparent to a tech if you ever chose to warranty the device.
sorry so wordy..
-mike :)
0
Score
Tony
79
Answered
0
Score
Answered
0
Score
Pomme123
Answered
theres a few of these in the iphone 4. in my opinion (only caus i know im now missing this bit cause it fell out and i could get it back in) is that up top just under the horizontal display cable there is a screw that is supposed to go in there. in between the metal chip cover and the motherboard there is suppose to be one of those, thats the one thats gone on me, but if i were you i wouldnt worry about it
0
Score
Answered
Yes. This collar is under the yellow circle screw from that link above. Mine popped out though the phone seems to work without it, it is disturbing not to have in there. All instructions for logicboard removal should warn the person on this as it pops out. It is so tiny that trying to reposition it (better caution could have been taken) it shot out somewhere in my kitchen. I may make a small collar out of aluminum since I am concerned this MAY minor-ly may effect the grounding. If you are like me it is quite disturbing to have something not go back in a disassembly the way it was or missing. Just about NO information about this is available AND the collar or insert is not in any IPhone 4 screw kits I have seen
It dosent look like a Pentalobe, are any of the screws missing on the bottom of your phone?
Michael C,
