JBL Flip bluetooth speaker.Portable wireless speaker that is great when you are on the go. Released September 14, 2012 *Note not the JBL Flip 2
27 Questions View all
Why my JBL Flip not charge EVEN AFTER battery replacement.
So recently my JBL Flip's battery reached 5 years old and it's not holding much capacity.
So I decided to replace it. But was not successful finding a correct battery. So i put it all back together. and attempted to charge it. Red light flashing and unable to charge. Help?
Add a comment
1 Answer
Most Helpful Answer
Arthur Mixed I am somewhat confused by your question. you said you replaced the battery but could not find a correct one. Either you replaced it or you did not. If you did not, then it is your battery that is no longer working. If you did replace it then it could be your charging port. You will need a multimeter to measure it on the board while your speaker is plugged in and see if you get power to it.
Do not give up looking for a battery. A lot of times you can find substitutes at places like this. It may take a bit of browsing, but I am certain you'll find one.
Score 2
7 Comments:
Ok so the guy that i asked for the battery, he said it has to specially made. So i gave him my Original battery (which still works before) to make the new battery, now BOTH battery wont charge :/
by
I just really want to know what does flashing red light while charging means.
by
The red blinking light indicates an issues with either the battery or the charger. In short it is not charging.
by
I have removed the battery and attempted to charge it. And the red light is still blinking, does it mean that it cannot detect a battery, or does it mean that the charger is faulty?
by
I'd go with a bad battery first.
by
Show 2 more comments
Add a comment
Add your answer
Arthur Mixed will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 21
All Time: 4,337
