Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
How sure or acurate is 3Utools. battery design capacity is 0
how sure or acurate is 3Utools. Because iphone 5 battery design capacity is 0. Mah 100. And 0 time charge.
I know the battery is really weak and needs replacement. But it can still go for about 24hours in idle mode, and 2-3 hours wifi and 1 on data network usage.
The iPhone heatup and hang during usage. Is this part of the Battery?
Mind you the backlight screen is dark. I am only using pc mirror.
Thanks
Score 1
1 Comment
Hello, would you mind offering the screenshot on 3uTools which shows that your design capacity is 0?
by
Add a comment
Chosen Solution
3uTools and all of the other utilities that read battery information, are just relaying the info the battery spurts out. As such, there is no precision issue at play here. The data you are seeing certainly doesn't feel right. If your phone is working and you are getting those readings, then I suspect there is something wrong with your battery or the filter on the BATTERY_SWI line is missing or damaged.
As Grace suggested, feel free to post a screen shot.
Score 2
Add a comment
My iPhone 7 says 92% battery capacity in the settings, but in 3utools it is 5%. The reading in 3utools is probably accurate because the phone is draining really fast, but i want to know why. It is just after a screen replacement. Please someone help.
2 Comments:
You are probably using one of those fake replaceable battery. They don't last long imagine 200 charge circle and already failing.
by
sorry for bumping an old thread, but there might be another reason some iphones are showing a good battery percentage while it doesn't last an hour: a lot of phone shops (many here in dubai) are using a device called "JCID battery booster" as it fake boosts the battery so it will show the result of 100% for example (or less to make it more authentic) on the devices battery menu. the only solution to spot such a fake battery setting is to reset the phone to it's default factory settings but all shop owners won't agree to it before purchasing the said phone. so be aware. my advise is to either purchase a used phone from a know trusted person or proceed to the last resort: Apple . this way you will purchase a phone that will give you a piece of mind (hopefully).
by
Add a comment
Actually this is what my second iPhone XS Max shows when I connect to coconut battery it says 99.6. And it still last a good day use as though no battery error but I still got that battery info in health section seller claims phone hadn’t been opened
Add a comment
pls can u help on me on the originality my iPhone XS Max hootenanny second hand seller claims battery not changed 3utools confirmed it’s the same battery as factory value and though it still lasts me a day use with no shirt downs at all pls help my curiosity
Add a comment
Add your answer
Albany Bet will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 93
All Time: 8,882
