Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 Questions View all
2 Broken phones, one LCD and one glass cover
Hey everyone, I have two damaged iPhone 3Gs's.
One has a shattered glass touch screen, the other has a cracked LCD display screen.
If I were to purchase the "Display assembly kit" found here:
[linked product missing or disabled: IF142-002]
Would I be able to split the pieces up and fix both phones?
I assume for one phone I would need the touchscreen glass with integrated digitizer and the other phone would need the LCD. Then I would have a bonus ear piece speaker and home button, correct?
It would be cheaper to purchase the $99 kit and split it up, rather than purchase the $70 Front panel assembly + the $70 LCD display.
What do you think?
Score 1
Add a comment
1 Answer
Chosen Solution
More than possible- it's what I'd do. Just take it easy so you don't end up buying more bits! Once you've got the front panels off you should be able to remove the LCD and push out the broken glass. Make sure you go easy with the black rubber seal or the final look is shabby.
Score 3
2 Comments:
Thanks!
When you refer to the "black rubber seal" - Is that glued to the glass touch screen?
I assume because you tell me to be careful, a new one is not included with the kit?
by
Actually might not be a problem because you won't need to take glass out of broken frame at this stage! The seal is on the midframe not the digitiser itself but when the glass breaks it can cut into the seal ( I made mistake of pulling bits off) as you'll have 3 midframes ( black plastic that holds digitiser and LCD/ home button and speaker) you'll end up with a spare ( the one with broken glass) and the othr 2 all you're doing is swapping out the LCD s. You can't buy new seals.....
by
Add a comment
Add your answer
Ryan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 1,837
