Repair information and guides for the fifth generation of iPhone. Model: A1387
2201 Questions View all
iPhone 4s broken battery connector repair
My iPhone 4s battery connector got detached from the logoic board, after soldering it back iPhone isn't charging and restart every 3-4 minutes like screen goes gray black and apple logo comes.
I have one more battery tested with that but there is no difference.
Battery was 57% and 2 hours later 40% while connected to the charge.
Edit:
Have a look at the detached battery connector. Please suggest can it be repaired or not.
Score 3
Add a comment
Most Helpful Answer
It can be repaired I believe that
Score 1
Add a comment
Your battery connector is not properly installed one of those pins is not getting good contact that's why the iPhone is acting up good luck I have soldering those tiny pins I had to solder and resolder my battery connector 4 times to get it working again GOOD LUCK
15 Comments:
Hi Mario thanks buddy for the suggestion but i checked all the connector using a multimeter they were connected properly though.
by
So there continuity to each pin?
Did you accidently remove any of the tiny resistors by the connector?
by
I ran into the problem your having and it's stressful and a pain and I noticed that 1 or 2 things this is assuming the charger and cable are working correctly was 1. Replacing battery and 2. Resolder the plug once again
by
I never felt that there is any resistor near the connector.
by
I resoldered 3 times and everytime checked i got the same issue.
by
Show 10 more comments
Add a comment
There should be ics by the connector ignore the jumpers on the image because I can't remember if this was the 4 or the 4s but you should have components next to the connector
2 Comments:
I just stopped looking for the answer I have tried a lot also i got few issues like i got it repaired several times from a shop and i found out there that there are no components near the battery connector i think those jumper got detached.
or might be I have lost all those resisters.
by
You have provided for the 4S
by
Add a comment
Add your answer
Sabhay Sardana will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 16
All Time: 2,770
