no bootable device insert boot disc and press any key
no bootable device says to insert boot disc and press any key
janicecallander sounds like your computer can no longer read the OS from the hard drive. Could be because of corrupted files or because of a failed hard drive. Try to get into the BIOS of your computer and see if it recognizes the hard drive in there. You can also set the boot order to USB/Optical drive and then restarted your computer with a bootable drive in which ever option you selected. From there try to see if you can access your original hard drive. I prefer to use something like a Live CD of Puppy Linux and try to recover the files. Ultimately it sounds like you will need a new HDD and/or OS. If you can let us know what model your Compaq is I am sure we can assist you further.
I have this problem too. Mine is a compaq presario cq60. Windows vista os.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 6
All Time: 4,728
1 Comment
no bootable device --insert boot disc and press any key
by janicecallander
