Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
798 Questions View all
it powers on but it wll not go any further .
I have a Apple iPod 5th Generation Black (30 GB). It shows the apple logo when it is on, but will not go any further. I can hear noise when I place my ear to the back of it like its will not give me a screen to select any thing help please.........
Score -1
1 Comment
missy just wondering if this was still a problem or if you got it fixed.
by
Add a comment
Most Helpful Answer
missy, first try to reset your iPod Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If that does not work put your ipod in disk mode by Before manually placing the iPod into Disk Mode - verify that it has a charge, if not you need to either charge iPod before continuing or connect it to power. Either connect it to a high-powered USB port, or connect the iPod to the Power Adapter and pluf that into an electrical outlet..
Toggle the Hold switch on and off. (Set it to Hold, then turn it off again. Just slide back and forth. )
Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
Disconnect iPod from the power adapter and connect it to your computer; the screen on the iPod will change and say "Do not disconnect"
You also have a diagnostics mode on your ipod that can help you identify a few issues. To place your ipod in diagnostics mode just follow the instructions on http://www.wikihow.com/Access-and-Run-Di... good luck to you and let us know what helped.
Score 2
Add a comment
sounds like the drive might be bad? Did you drop it recently? I have the same one...
Add a comment
bang it with the heel of your hand, seriously, ive heard of these drive heads getting stuck, you bang it while powered on, and it begins to work again. funny, but true
1 Comment:
crevz, you are right too. X red on display and : apple.com/support "Some people repair it by the "slap-the-back" method. Some times when you drop your ipod the lens inside skips. This can also happen with other incidents that are not as violent as dropping it. Reset your ipod by holding the middle and menu button until you hear clicking, then with one hand hold the ipod firmly and hit the side of it onto the PALM of your other hand. Sometimes this jumps the needle back into place but not all the time. It may also require a few attempts since most of us are not willing to treat it like a 1970's TV :) NO GUARANTEES ARE MADE HERE AND I WILL NOT ASSUME RESPONSIBILITY FOR ANY DAMAGE :) There are also multiple threats out on it even answer here on ifixit Why does my iPod show a red "x" in a circle?... and http://www.pinkbike.com/forum/listcommen... :)
by
Add a comment
Add your answer
missy will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 737
