Colored vertical lines on screen
Colored vertical lines on screen then it clears up but it's taking longer and longer to go away
A picture would be helpful, one when cold, one when it is 1/2 way cleared, and one when the lines are gone. However, it is either the T-con, or the tabs on the LCD glass inside the panel, or the contact between the T-con and the panel. You can open up the set and remove the flat ribbon cables between the T-con board and the panel and clean them (with a pencil eraser) and re-seat them to see if it is going to be the easy fix. Otherwise it will likely be too costly to repair or even replace the panel. Good luck...
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 9
All Time: 2,558
