2008 netbook; Model ZG5 AOA150-1691; 8.5" screen; 1.6 GHz N270 Intel Atom Processor
74 Questions View all
Replacing motherboard -will xp operate automatically?
Hi -- I need to replace the motherboard on my ZG5 (too many problems trying to install replacement power jacks). Should the XP operating system work automatically once I put everything back together (i.e.--does it exist completely on the hard drive?) or am I going to have to re-install XP. This computer didn't come with any restore discs, etc.
Thanks
Score -1
1 Comment
Thanks --I hope that's the case --I'll let you know how it works out!
by
Add a comment
1 Answer
Chosen Solution
You may have a partition on the HDD that has your XP on there. I have had it on my Dell and Toshiba. Anyhow, when I replace my motherboards I usually end up having to install the drivers for that particular motherboard since they will be different and windows will tell you that it has found new hardware. So make sure you have a disk with all the drivers for your new motherboard and follow the install instructions. At this point you really have no other option than to give it a go or purchase a new copy of xp as well as having a disk with all the drivers for your Acer. I hope this makes sense and it is really not all that bad and complicated. Good luck and let us know.
Score 1
Add a comment
Add your answer
Brian Mott will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 936
