The Sony Ericsson Xperia X10 Mini E10i runs on a custom version of Android and features 3G access. Released in 2010.
33 Questions View all
Why does my se x10i says my SD micro card is emty?
Lost my phone on the flor and after that it says my SD micro card is emty,i have split it open and found out that resistor connectet to conector 8 on the SD reader was broken, cant measure the resistor. is there enyone that know the value of it?
thank You for the teardown session.
Score -1
Add a comment
1 Answer
Chosen Solution
The value of the resistor is 55 ohm. SMD number 0402 that meens 0402 (1005 metric) : 0.04" × 0.02" (1.0 mm × 0.5 mm) Typical power rating for resistors 1/16 watt
1 Comment:
Congratulation Olafsson on your research. Now all you have to do is accept your own answer and then we know this question is answered. Great Job...:)
by
Add a comment
Add your answer
Olafsson will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 1,067
