MDR-ZX100 ZX Series stereo headphones made by Sony.
20 Questions View all
Both the speakers are not working
Both the speakers are not working and I have checked the whole wire and it is working for another speaker and I have connected the speakers with another wire it not working...hence the problem is with my speakers. Please help
Add a comment
Most Helpful Answer
nitheesh k unlikely that both speakers have failed. Check the 3.5mm plug. Check it and replace it as necessary, follow this guide Repairing Skullcandy SCS-SCBP SKULLCRUSHERS 3.5mm plug to do so. Different model headphone but identical procedure. you can also check the wiring to the drivers (speakers) by using this guide How to repair Sony MDR-ZX100 and measure continuity with a multimeter from the connector to the drivers.
Skullcandy SCS-SCBP SKULLCRUSHERS Image
Guide
Difficulty:
Moderate
45 minutes - 1 hour
Sony MDR-ZX100 Image
Guide
Difficulty:
Moderate
15 - 30 minutes
Score 1
Add a comment
The problem is most likely with your speakers, but it is unusual that both speakers fail together. Are these speakers connected to a computer? Such have a power supply inside one of them and if that fails the speakers do not work. As most of these have an external wall-plug supply, check this (measure voltage at the output plug). If there is no voltage just replace the "wall-plug" supply with one of the same voltage and Ampere rating.
If your problem is with regular speakers that you connect to am amplifier I have no idea what may be wrong with both of them.
Add a comment
Add your answer
nitheesh k will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 21
All Time: 146
