0
Score
Leah
Asked
Dropped iPhone- checked connectors-Replace entire display or just LCD?
Ok, my husband dropped his iPhone 3G today and the screen is white with a black stripe down the right side and a few colored stripes here and there. I took the screen off and checked all of the connector cables. The #1 cable comes off VERY easily (all you have to do is pull the screen up past 45 degrees and it comes off), so I imagine that is where the problem lies. The phone itself is working fine. It can receive a call, make a call, it syncs to iTunes, etc. The only problem is the screen.
Should I replace the entire display system or just the LCD? I'm not sure which is actually broken.
0
Score
Marc
771
Answered
Leah,
If the digi glass isn't cracked or broken it is likely that it is just the LCD, however if it were me I would replace the entire thing. That is the easiest way to do it as it is the entire assembly and pretty much plugs and snaps in. They are $99 here:
You should be able to do it in a matter of a few minutes since you have already had/have it apart.
