Repair information on hard drives or hard disks. Hard drives are magnetic data storage devices. They are used in most desktop, laptop, and server due to their low cost and high data density.
146 Questions View all
Hard disk not detected after hide all folder inside
hi all, I need help for this after give up find solution
I have an hard disk from my old Toshiba laptop and now im using it as external hard disk after buy new casing. last night I hide all folder inside to make it look clean and empty then the next day when i want to use it my computer detect the hard dist but didnt show up in my computer list it only show "USB Drive(F:)" with hidden icon (blur) and cant open it. I did found few way to fix it but still not work for me
3 Comments
What Operating System are you running?
by
im using windows 10 64bit
by
1. Have you tried opening it from Disk Management?
2. Do I correctly assume that you need to save the files that are stored there?
by
Add a comment
Most Helpful Answer
To show hidden files and folders, open file explorer, click the "view" tab at the top, click the "Options" button in that menu, then click the "View" tab in the new box. From their, select "Show hidden files, folders, and drives" from the list. Then click "OK."
Hope this helps!
Score 1
Add a comment
First hidding the folder has nothing to do with hard disk no appear in my computer. You said that it is detected but not shown in my computer. Do you check device manager for found new hardware?
Right click on your usb drive f and then property then tool and then check for error.
Better i suggest remove hard disk from usb cashing and then again insert it.
Score 1
Add a comment
To show Hidden devices from Device Manager, here are the detail steps, hope can help you:
1. Press Win Key + X to launch the Shortcut features from Start Menu, for Windows 7 User, you can press Win Key + R and type devmgmt.msc
2. After that, hit on the tab View from the menu bar, check “Show Hidden Devices“.
3. Then expand all hard drive device lists to find whether there is the device with the light gray icon. Select them and uninstall.
4. Restart your computer and check if the problem has been fixed or not.
1 Comment:
And here I found a site that offers several solution to fix the hard disk not detected, hope can help you: https://www.r-datarecovery.com/how-to-re...
by
Add a comment
Add your answer
gsdhe4y2fsdg will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 193
