Repair information for the Fitbit Charge HR. Released in January of 2015. Model numbers: FB405BKS (small) and FB405BKL (large).
66 Questions View all
My charger shows a thin battery, and jworks for two minutes and then
The Fitbit thin line battery comes back. It gives info on steps for a minute and then is dead. I charge it, it shows the battery charging and then it dies and goes back to thin rectangle in screen.
Add a comment
1 Answer
Chosen Solution
@itaplus3,Yvette, Use the 1st link for Fitbit charging problems/solutions. Sounds like you may have a faulty battery. If under warranty return for repair/ replacement /refund. If not under warranty and you would like to attempt battery change use link below. If your model differ's comment back and I will see if I can find you the battery changing guide. 3rd link is to a replacement battery. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://help.fitbit.com/articles/en_US/H...
Fitbit Charge HR Battery Replacement
http://www.ebay.ca/itm/Brand-NEW-LSSP-LI...
Score 1
Add a comment
Add your answer
Yvette Aguirre will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 14
All Time: 133
