Repair and disassembly guides for desktops manufactured by Acer.
70 Questions View all
opening the am3400 case
I want to open the case of my AM3400-U2052 without a crowbar. So I can have a look around. My sound is sporadic and I suspect a poorly wired socket for the speaker plug or a poorly seated card. But first I have to look under the hood and the case refuses to come off.
Add a comment
1 Answer
Chosen Solution
Tom Franczak, Normally there will be a couple screws to remove from the back that hold side cover, then slide the cover back a 1/4" to unlock from frame tangs and lift cover off. The link below is to a service guide(not your exact model) but will show side cover removal/instruction. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.manualslib.com/manual/232867...
Score 3
Add a comment
Add your answer
Tom Franczak will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 13
All Time: 141
