Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1170 Questions View all
No display Not recognize by iTunes After Repair
I was going to check the LCD and forgot to turn off the iphone before taking LCD From logic Board . returned every thing back but iphone doesn’t start , iTune not recognize it , I used all methods to reset but no chance Did I fry the Logic board by not turning it off before taking apart? can this be fix? thank you
Update (01/23/2011)
I got it today Form repair shop . they told me that Motherboard was effected and they change some IC on the Board , i don't know whats that , but its working fine , i opened the phone and its same motherboard and same LCD . i don't know what they did actually
Add a comment
1 Answer
Chosen Solution
-Check contact points for burn marks.
-Test LCD in other iPhone
-Do a hard reset as well
-Flip ringer up/down to see if vibrator responds
2 Comments:
No you cannot. You will need to test the LCD into another iPhone 3G. The 3Gs will not work.
Find a friend with a 3G and swap it. If your LCD comes up fine, may be your logic board.
I personally never turn a phone off when changing the LCD or Digitizer.
by
No Burn marks
Nothing with hard reset (Home+Power)
No vibration
can i use LCD on 3GS ?
by
Add a comment
Add your answer
Mahmood will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 978
