My tv says maintenance mode?
Samsung led tv just says maintenance mode? What to do?
@rl147 if anything else fails try a factory reset. This will clear all your presets and any favourites you have set
1: Make sure your TV is on standby (i.e. off, but plugged into the wall)
2: Using your remote, press the following buttons in exactly this order: INFO – MENU – MUTE – POWER.
Note: You have to press them rather quickly one after another, and make sure the remote is properly pointing to the TV.
3: The TV will now switch on, and after a moment, display the service menu. If after about 10 or 15 seconds the service menu doesn’t appear, switch off the TV and try again.
4: Press the Options button (It’s the first option).
5: Press the Factory Reset Button (Again, it’s the first option).
6: The TV will now switch off.
7: Switch the TV back on, and begin the full setup process from the beginning. From here. Let us know what you get.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 28
All Time: 4,538
1 Comment
@rl147 what exact model is your TV?
by oldturkey03
