Model A1311 / Mid 2010 / 3.06 & 3.2 GHz Core i3 or 3.6 GHz Core i5 Processor
343 Questions View all
Will a 2011 logic board fit in a 2010 shell?
Hello,
Recently, I was given a 2010 iMac from a friend, as it is broken. I was curious before I go out and buy a new logic board for it (as I have confirmed that it is a dead logic board) whether or not I would be able to put a 2011 logic board into it instead of a 2010?
1 Comment
I had the same question, but the other way around. Just bought an iMac A1311 (2011) and wanted to check compatibility between the year 201 and 2011. Obrigada! Thank you!
by
Add a comment
Chosen Solution
Typically it is not possible. There are too many varying parts between the years to allow it to fully work.
The 2009 and 2010 models have more similarities than the 2011 model.
Ultimately, i've not tried it between the 2010 and 2011 models, but with the difference in so many of the parts (the only real similarity in major components is the PSU).
SO you will only know for sure if you had them sitting side by side for comparison, then took the risk by fitting it to the machine. Sometimes there are minor component differences that handle voltage differently to other boards, so its definitely a risk, so i'd not suggest it unless there are many similarities between the ranges in question.
I hope this helps.
Score 3
Add a comment
iMac 2010 support LGA 1156 CPU
But iMac 2011 Support LGA 1155 CPU
Both GPU is MXM card but card rate is different
iMac 2010 support HD 4670m and 5670 M
But 2011 is different.
Ram is the same but capacity is different
You can install 16GB on 2010
But 32 GB on 2011
Place of scroll is also different
2010 USB port and display port and FireWire port is different to 2011
LCD data cable is also different
On 2010 iMac you can install core i 7 860s
You can install windows 10,11 in both model
Firmware bios SMC is also different
Power Frequency is also different
Update (06/15/2022)
But 32 GB on 2011
Note : you can install GTX 880M 8GB on iMac 2011 27 inch
Add a comment
Add your answer
Scott Currier will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 786
