Steering wheel wobble an steering block noises
Steering wheel started wobbling then ther was a nocking noise under bonnet everything is solid well maintained I think it's the steering block
shawnqueeley Its time to replace the steering fluid in the rack . This video will help https://www.youtube.com/watch?v=Iev1xIr3.... I cannot stress enough USE HONDA POWER STEERING FLUID. Regular steering fluid is too thick and will cause problems . Hope this helps
check your tires for bulges or uneven (snaky) tread, loose lug nuts, bent rims. Also check the steering fluid level and drive belt tension.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 218
