The Nikon N80 (also known as F80) is a 35mm SLR Camera. It was released in January 2000 and is identified by model number 1776.
5 Questions View all
Is it a brick?
Hello!
I just bought a used Nikon N80. It seemed to be in perfect condition, but I took it home and discovered a focusing problem.
The image in the view finder is dim. And when I try to focus, the lens goes in all the way and back out to infinity without finding a focus point.
I tried a few lenses with the same result.
I checked the sensor at the bottom of the chamber, and it's clean.
Like I said, the camera seems to be in great condition otherwise.
What do you think? Is this a brick, or can I fix it?
I should also mention that I bought the camera with the lens improperly attached. I had to carefully cut a tiny piece of plastic off the lens mount to get it off.
Fortunately I paid only $20 for it, plus new batteries.
Thanks for any input on this!
Eric
Add a comment
1 Answer
Chosen Solution
Eric Zulaski I wonder if you have trouble with the AF unit or if an adjustment would work. Since you are only in for $20 it maybe worth your while to get the repair manual from this page (under "Document") and go through the adjustment routines etc.
Score 3
3 Comments:
Thanks for the tip. I will certainly give it a try.
by
I had been on the guide page, but I didn't notice the repair manual tucked in there.
by
It's a present added after you asked the question
by
Add a comment
Add your answer
Eric Zulaski will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 23
All Time: 156
