broken connector for the camera and FaceTime
The silver connection for the camera cable has broken off at the board. Is this fixable on a MacBook pro A-1398? If so where can I buy the connector. Its a flimsy connector that takes very little to displace from the board.
Ever since this happened my fans continue to run at high speed. I have attempted on several occasions the recommended resets by apple but this hasn't solved any of the issues.
Score 2
2 Comments:
Did you figure anything out? Happened to mine as well. Thanks
by
Melted the connector. No sucess
by
Add a comment
1 Answer
I am assuming that you have a 15" Retina MacBook Pro model between late 2013 and mid 2015 - you wrote A1398 in the question but chose a different model to file the question under.
You can replace the connector, however, this will require soldering equipment and some experience with microsoldering. You can buy the replacement connector here: https://beetstech.com/product/isight-cam...
Add a comment
Add your answer
Kevin will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 18
All Time: 445
