Eighth generation of the Honda Civic.
59 Questions View all
Bottom front panel is loose
The bottom front panel of my isn't fully attached along the sides (by the wheels), probably due to parking a bit too close to the curb a few too many times. The panels keep popping out along the sides. Any suggestions for how to get them to stay put?
Add a comment
1 Answer
Chosen Solution
zlisto , You may have to purchase new plastic push rivet retainers (Link below)or if they are lower ones that cannot be seen, perhaps you can use the medium size pull ties. If the lower valance holes are worn to a larger size and held by bolts or screws insert a larger washer to prevent pull through. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.amazon.com/Partsam-Fender-Re...
Score 1
Add a comment
Add your answer
zlisto will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 19
All Time: 633
