Repair guides and support for motorcycles manufactured by Yamaha Motor Company.
89 Questions View all
What is the minimum and original thickness for motorcycle brake rotor?
I'll like to know when should I change my brake rotor.
What's the minimum front and rear brake rotor thickness and what's the original thickness for Yamaha xt600e 2002.
1 Comment
Ok thank you. I got one more question.
My xt600e originally had a 21 front and before I had it the person changed it to a 17 front.
It may be a idiot question but my stock rotor for xt600e would it fit the now 17 rim?
Or do I have to find/get a rotor specific for 17 rim?
by
Add a comment
Chosen Solution
derayon, I beleive this to be the dimensions of your stock rotor. You can compare the dimensions to the rotor that is on the bike. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Dimensions (mm)
Outside Diameter 282,0
Inside Diameter 132,0
Bolt Hole Circumference 150,0
Bolt Hole Quantity 6
Bolt Hole Size 8,5
Thickness 5mm new
Minimal Thickness 4.5mm
Offset 0
Bolt Hole Type Straight
http://www.ebay.com/itm/MetalGear-Brake-...
Score 1
2 Comments:
derayon,did the info. help.
by
Yes it did help thanks
I checked it today and it seems to be the same
by
Add a comment
Most Helpful Answer
4.5 mm is minimum and they should be the same on the front and back.
Score 1
Add a comment
Add your answer
derayon will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 104
All Time: 6,506
