Black wire on control board
I took off the water /ice dispenser control board to clean the dispenser . There's a black wire attached to the board where does the other end go to
Hi,
This link may be of some help in solving your problem, if you can read a wiring diagram that is.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 468
2 Comments
Missy, add your make, model and model#, was the wire ripped from a connection or is there still a connector on it. this info. will help ifixit volunteers to answer your question more effectively. Good luck.
by L Pfaff
It's a GE gfe28hmhees french door bottom freezer. The connector and wire are attached to the control board. I have no clue where the other end with a connector goes
by Missy
