My sanyo tv volume
My sanyo tv turns on just fine if i turn my volume above thirty my tv shuts off
dennis hoff , Probably a shorted audio amp IC(capacitor), the 1st link below discusses the issue. The 2nd link you may perhaps be able to get your service manual if not try a search using your make,model#. If not wanting to do the repair your self or if under warranty have a good local TV repair shop have a look and estimate repair. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 49
All Time: 13,468
7 Comments
@denhof to properly trouble shoot your TV we would need to know what model it is. Double check any menu options to ensure that the TV is set to regular audio out.
by oldturkey03
My sanyo TV sound went out
by Kevin Wilson
Hi Kevin Wilson,
What is the model number of your TV?
What input are you using?
If using HDMI or AV input have you checked that the audio source is OK by trying different source, different cord, different input?
What audio output is connected, internal TV speaker or external audio amp?
What have you tried?
The more relevant details about your problem, the better the answer.
Post your comment as a new question on ifixit. That way it will get more attention.
by jayeff
I put my audio in the the part it supposed to go and I don’t know what channel it to be on, does it supposed to be on tv? Hdm1?Hdm2? Or video
by Zay
Hi @zaygothoes_ ,
What is the model number of the TV?
What type of device (audio device or a device that has audio and video) are you trying to connect to the TV?
What is the make and model number of it?
by jayeff
Show 2 more comments
