My speedometer stopped working after the radio was stollen
how to fix speedometer after stereo was stollen
Matthew Budau , Check all your fuses if all test good, you will have to look under dash and examine all the wires/plugs to see what all got cut, loosened or damaged and make necessary repairs. I hope the links below may also help, wire color codes and schematics. It could also be a problem with stepper motor behind the cluster which may have failed, last link below. Good luck.
http://www.jalopyjournal.com/forum/threa...
http://www.autozone.com/repairguides/Ava...
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 6
All Time: 155
