Support for gas-powered and electric golf carts, sometimes referred to as golf cars or club cars after the Club Car Golf Cart brand.
495 Questions View all
Golf car runs when cold after warming up quits moving forward or rever
My ez go gas golf cart runs fine when cold after it warms up its like the trans went out wont go in forward or reverse at first it would still run in reverse for awhile about 5 more mins and then nothing in either direction .After cooling down overnight then it would run fine for about 20-30 mins and then quit going again .
Score 1
1 Comment
I have the same problem and I have replaced the belt and clutches and the problem is still there.I even changed cdi box new rear end carb and accelerator cable new coil..Nobody can figure this out..ive spent over 1100.00 trying to solve issue.
by
Add a comment
1 Answer
Chosen Solution
@musicman4577 , billy, Sounds like a drive belt or clutch issue, check the belt for being worn, when a belt gets to a certain thickness(worn) it will cease to work when warm or may not work at all, replace the belt or if adjustable, adjust. Check your clutch for proper function and wear. Check the links below to help trouble shoot your cart 2nd link is the service manual for gas powered carts. Good luck.
http://www.golfcarcatalog.com/golf-cart-...
http://www.specialtycartz.com/pdf/ezgo_g...
Score 1
Add a comment
Add your answer
billy will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 17
All Time: 2,118
