Repair guides and support for your Sanyo TV.
360 Questions View all
Tv remote volume is not going up or down
I have a 48" sanyo tv flat screen and the volume will not go up or donw i have to get really close to it for the volume to work like the remote is touching the bottom of the TV for the volume to go up and down and it should not be doing that.
2 Comments
Mines is stuck on volume down ? Somebody help
by
@mr.thomasblack3 ,
What is the model number of the TV?
Try removing the batteries from the remote control unit and then using the TV controls (usually on the side or below the screen if it has them) to raise or lower the volume and see if this works.
If it does then check that the remote Vol. Down button is not stuck etc. Did the remote get wet at all?
by
Add a comment
Most Helpful Answer
Mrburgh , First thing to try is another set of good quality replacement batteries and wipe the remote and TV sensor with a soft cloth to clean of any dust. Also find links below that tell how to test and clean/repair remotes when buttons not functioning well. Good luck.
https://www.youtube.com/watch?v=sTgfWxcR...
https://www.youtube.com/watch?v=5G8xIqoX...
https://www.youtube.com/watch?v=gVr8eLW0...
Score 2
Add a comment
Mrburgh since this is only happening for the volume, I'd suggest you try a universal remote on your TV and see if that works better. If it shows the same results you may have issues with the IR receiver board on your TV. Let us know what you find out.
Score 1
Add a comment
how to fix when Device Won't Respond to Remote Control Commands
Make sure your components are turned on and yourTV is set to display the appropriate video source.
You must put the remote in the correct mode bypressing the corresponding component key (TV,DVD, VCR, AUX, SAT·CBL) so the remote knowswhich component you want to operate.
Remove any obstacles between the remote and thecomponent. Make sure to aim the remote at the IRsensor on the component.
Make sure the batteries are fresh and are properlyinstalled. Replace the batteries with two new AAAbatteries, if necessary. Reprogramming may berequired.
Reset the remote using these steps. If the indicatorlight lights up, reprogram the remote and try again.If it doesn’t light up, replace the batteries with newones
you can find the up-to date Sanyo remote codes here
Add a comment
Add your answer
Mrburgh will be eternally grateful.
Past 24 Hours: 11
Past 7 Days: 73
Past 30 Days: 370
All Time: 7,755
