when I press the gas nothing happens
replaced the battery solenoid valve and voltage regulator still nothing when I press the gas?
Here is a link to wiring diagrams: http://www.courtesygolfcars.com/yamaha-s.... They have both the G22A and G22E. Before spending more money on parts, I would take a multimeter and start checking components.
For example, do you get continuity when the key is turned in the key switch, and do you lose continuity when you turn the key off. If so, then there is no need to spend money on the key switch.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 1,218
mg101474 what make and model is it and what have you checked thus far?
by oldturkey03
Its a 2006 yamaha g22.
I've already replaced the battery voltage regulator and solenoid valve.
Next I'm going to try the accelerator switch and the key switch
by mg101474
I have a g2 1990 that I have the same problem I know there is no spark in the plug
by rey12345
