The third generation of the Samsung Galaxy tablet with a 7-in. screen announced on June 24, 2013. Repair of this device requires screwdrivers and prying tools. The device is available in white or gold brown with 8, 16, or 32 GB of storage, and includes a microSD slot that can hold up to an additional 64 GB of memory.
120 Questions View all
Intermittent charge Galaxy Tab 3
My Galaxy Tab 3 takes days, sometimes a week to charge while turned off using any charger,. Turned on, it goes in and out of charge mode and never fully charges, in fact, it actually loses charge probably because the screen and charge tone are constantly going on and off. It`s even worse using the OEM charger.
I have recently replaced the battery with an OEM part with no change.
Any help you people can provide will make you my heros and sheros forever.
Thank you
Bart
Add a comment
Most Helpful Answer
try going into settings and turn on power saver mode. Then turn it off and put it on the charger.
Score 1
1 Comment:
I turned on power saver, then powered down the device. OMG! It only took a few hours to charge! Thanks tecfix4u! ...whoever you are!
by
Add a comment
Re: OEM charger, did you use a new cable AND plug adapter? Cables can go bad as well.
Possible the charging port may be bad or damaged as well. Inspect it with a magnifying glass for any bad soldering, broken off jumpers, and broken pin(s). Have you replaced the charging port itself? Some tab 3 models have a port that is attached to the logic board by a (16?) pin connector. If you have one of those then replacement is EASY, otherwise you'll need expert microsoldering skills to swap out the charging port.
I'm assuming OS is up to date. Good luck.
Add a comment
Add your answer
Appliance Connectors will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 127
