The wi-fi only version of Apple's iPad Air, model number A1474. Available in Space Gray or Silver, it packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
299 Questions View all
ipad air wake sleep sensor
Good morning, I replaced the tuch on a ipad air (full touch home button) .. but no longer works the wake sleep mode with the smart cover .. do not understand what may be the problem .. where is the sensor?
Score 2
Add a comment
1 Answer
Chosen Solution
The sensor is the chips on the home button cable. Compare it to the old screen with the home button on it and you should see that one does not have the components on there.
If that is the case then you will need to transfer it via soldering.
Score 2
2 Comments:
Thanks for the answer, I doubt that the sensor was in the home key. I can't figure out what is the
Chip. Can you attach a picture.
by
My bad, the home button cable is soldered together with the screen.
It's just a bad digitizer then because most likely it didn't come with the IC required for the smart cover sensor.
by
Add a comment
Add your answer
Luca Ciclisti will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 1,002
