The Kenmore 90 Series is a washing machine manufactured by Kenmore.
268 Questions View all
sweet spot in the permanent press will make it work
Same problem, I checked my door switch with meter its OK. Changed my water level switch with new. No change. Replaced my timer with new (ouch) same thing. We have found their is a sweet spot in the permanent press second rinse spin cycle that will make it work. hope this helps.
Freezzman
Score 1
Add a comment
1 Answer
Chosen Solution
Check the connections at the motor for damaged or loose connections. Most washers have a 2 speed motor. The normal cycle uses the high speed all the time. The permanent press cycle will use the low speed during the cool down in the last rinse. That's probably the "sweet spot" you referred to. If you have a delicate cycle try it.
Since I don't know what model you have, my guess is the high speed windings of your motor are not getting the proper voltage or they are bad.
Score 3
1 Comment:
Thanks for the insight tried the prem press cycle did not work. when i get to it i take the cover off and check the wires
John
by
Add a comment
Add your answer
freezzman will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 178
