Comprehensive repair manuals for each of the six versions of iPod Classic sold from 2001 to 2014. Common repairs are battery and hard drive replacement.
2161 Questions View all
New and Old Battery Not Charging
My ipod video battery life was down to 20-30 minutes, so I bought a replacement battery. After installing the new battery and charging for 8 hours or so, I turned on the ipod and it worked fine. Then I unplugged the ipod from the charger and it immediately lost power. It didn't hold any charge.
I then put the old battery back in, figuring the problem was with the new battery, but now the same thing is happening. The old battery that used to last 20-30 minutes on a full charge now works fine when plugged into a charger but then immediately loses power when unplugged.
Any thoughts on why this is?
Score -1
Add a comment
1 Answer
My first guess here would be a bad battery. But I do know that the iPods do have issues with the charging circuitry. You could try to use a multimeter at the connector for the battery to see if you have any voltage. That might give you the answer you need to determine what to do next. Give it a try and let us know how it went. Good luck
9 Comments:
I feel like it can't be the battery since my original battery (that isn't fully dead) doesn't work either. I don't have the tool you mentioned. Is there a "poor man's" way of checking for voltage?
by
The only other way I can think off is to really charge the new battery for a while on a wall charger and not the computer USB port. See if that makes a difference. Just wondering why you changed the original battery since you said it is not fully dead? Did you experience any trouble related to battery/charge issue before you changed the battery?
by
Granted, there is also the possibility that you new battery is not charging but I have had more issues with the iPod charging circuitry than bad batteries.
by
Tim, the more I hear the more I am convinced that you have issues with the charging circuit on your Ipod. I suppose I could ask you to make sure that you have changed the USB cord to a different one etc. But I am almost certain that you are looking toward a motherboard replacement. Just let us know how it works out.
by
Oh, man. That sucks. Probably not worth spending $70 on. Any idea why the charging circuit would stop working when all the other ipod functions work perfectly if it's plugged in?
by
Show 4 more comments
Add a comment
Add your answer
Tim will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,271
