Eighth generation of the Mazda Protege.
49 Questions View all
My Protege is acting like its not getting enough fuel. Its not idling
My car is acting like its not getting enough fuel. Its not idling good and it runs rough going down the road. If you get over 45mph it feels like its skipping but it takes forever to get up to 45. If I stop at a stop sign or red light I have to keep one foot on the gas and one on the brake because it will shut off.
model: 2001 Mazda Protege
Add a comment
1 Answer
Chosen Solution
samanthaparker1971 , There a few things that could cause this issue, failing fuel pump, clogged fuel filter, bad injectors, faulty coil, clogged catalytic converter, major vacuum leak, EGR valve sticking, IAC control, Oxygen sensor, failing crank sensor, etc. etc.. Best to have the car scanned for trouble codes as a first step to help in finding the fault. Some of the auto parts suppliers offer free code reading like Pepboys, Nappa, Advanced auto parts,etc and some of the guys are very knowledgeable and may have seen the issue often and put you on the right track. If not comfortable dealing with the repair take to a good shop and have a technician take a look, diagnose and estimate repair. Good luck.
Score 4
Add a comment
Add your answer
samanthaparker1971 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 14
All Time: 2,019
